The driver side has heat but the passenger side is blowing cold air?
335,000 MILES
CARVEREOD
The heater blew only cold air, so I replaced Blend Door Actuator on lower passenger side. Now the driver side has heat but the passenger side is blowing cold air. I attempted to have system relearn (calibrate) by disconnecting fuse, wait, reconnect, run engine, turn off then turn on…the information for this method contradicts itself. I have seen where it says 10 seconds and 2 minutes for the fuse removal. So, I’m lost, can you please help?
Oct 22, 2022 at 3:00 AM
  • 55,732 POSTS
I believe the passenger side actuator is on the top of the HAVC system.
Here is a guide to help you see what's going on:
Scroll down to see the locations. Please go over this guide and report back.
Oct 22, 2022 at 11:07 AM
CARVEREOD
Okay. So, I replaced the Blend Motor Actuator on the 2003 Chevrolet Avalanche because it was blowing hot on the driver side and cold on passenger side. I replaced it twice. I'm still having the same problem. I attempted to have both parts "relearn" (calibration). I still have the same problems. The blend door actuator was located on the passenger side floorboard area. Can you help?
Oct 27, 2022 at 1:12 PM
