Drivers side blows hot and passenger side blows cold
112,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
JW38
HVAC not working properly.
Nov 29, 2021 at 1:19 AM
  • 110,246 POSTS
It sounds like there is an issue with one of the blend air door actuators. However, I need to know something. You indicated the driver's side is hot, and the passenger's side is cold. Which of the two is working correctly? Let me know. Otherwise, I don't know which is causing the problem. LOL
Just to give you an idea of how an actuator is replaced, take a look through this link. It explains in general how one is replaced.
I also will need to know if the vehicle has automatic or manual climate control.
Take care and I'll watch for your reply.
Nov 29, 2021 at 10:06 AM
JW38
manual climate control/heat control is working fine. Thanks, jw38
Nov 30, 2021 at 1:38 AM
  • 110,246 POSTS
Okay, so the passenger side isn't responding when heat is requested. If I misunderstood, let me know.
If you look below, the directions indicate the procedure for replacing the actuator. Take a look through it and let me know if you have questions.
See pic below.
Nov 30, 2021 at 8:06 AM
JW38
Joe, I have the glove box, the duct for passengers floor removed. i can see a actuator with the gears facing to the drivers side. It works fine. Is the one i'm looking for behind the console? Do i have to remove any parts of the console? Thanks, jw38
Nov 30, 2021 at 9:47 PM
  • 110,246 POSTS
The left side is the same procedure just the opposite side.
I attached the directions below. Let me know what you find or if you have other questions.
Dec 1, 2021 at 9:51 AM
