HVAC isssues
169,000 MILES • 4.7L • V8 • 4WD • MANUAL
DOFHER4421
can hear the blower motor working but not a lot of air is coming out of the vents. Also, can not switch air from face position to any other positions, such as feet defrost etc.
Jun 18, 2017 at 4:08 AM
HMAC300
  • 48,601 POSTS
try pulling HVAC fuse inside truck with key on for sixty seconds then reinstall. it may reset the actuators.it may also be vacuum operated system we have no pictures of anything on this system. mode actuator or vacuum motors are typically by gas pedal on heater system.
Jun 18, 2017 at 7:32 AM
DOFHER4421
pulling fuse helped with blower , still can't swith zones. Could it be the control unit that is bad?
Jun 20, 2017 at 12:48 AM
HMAC300
  • 48,601 POSTS
see if there is power to the actuator if the control unit is bad it has to be scanned for codes by a mechanic to see if it is then may need programming after replaced.
Jun 20, 2017 at 1:18 AM
