HVAC
150,000 MILES
VINCENT GRANT
I have air blowing through the defrost, middle, and floor vents at the same time. However, if I select the defrost, the windshield clears up relatively quickly. When I increase the temperature, the air on the passenger side heats up as expected. The air on the driver's side remains cold.
Jun 15, 2018 at 11:05 AM
Good afternoon.
The actuator on the left side sounds like it is not functioning. I attached pictures and the procedure for replacing it.
As far as the other issue, do you have sufficient air flow from the vents with the AC on?
REMOVAL PROCEDURE
imageZoom/Print
1. Remove the left instrument panel insulator.
2. Remove the knee bolster.
3. Disconnect the electrical connector from the temperature valve electric actuator.
imageZoom/Print
4. Remove the mounting screws from the temperature valve electric actuator.
5. Remove the temperature valve electric actuator.
Jun 17, 2018 at 4:13 AM
