HVAC not blowing air
178,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CODIE SCHNEIDER
This air doesn't blow at all. I have changed the cabin filter the blower motor and the blower motor resistor none of that has worked.
Jan 6, 2020 at 12:49 AM
  • 110,248 POSTS
Have you checked the blower motor relay and fuse? If you look at pic 1, I highlighted both which are located in the engine compartment fuse box. If you haven't done this, check them and let me know what you find.
Here are a few links you may find helpful:
Let me know what you find.
Jan 6, 2020 at 12:56 PM
