Humming/roaring
209,338 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
LUCKY86BAMA
When accelerating and let off the noise get louder but when turning it almost stops.
Dec 14, 2019 at 1:41 AM
More than likely this is a wheel bearing or another bearing. By turning you are loading and unloading the bearing and the fact that it makes the noise when accelerating and decelerating, I suspect it is a bearing in the differential. However, the wheel bearings are easiest to check so I would start with those.
https://www.2carpros.com/articles/how-to-replace-front-wheel-bearings-and-seals
https://www.2carpros.com/articles/car-howling-noise
Dec 14, 2019 at 10:20 AM
