2009 Hummer H3 Gas pedal vibration on 09 H3T
2009 HUMMER H3
JLANDO
  • 6 POSTS
2009 Hummer H3 Four Wheel Drive Automatic 1500 miles
My 09 H3T is experiencing a pretty noticable vibration in the gas pedal while the engine is under load at approxiamtely 2500 to 3000 rpm. I can feel the vibration also in the floor board. I was told that there was a tech bulliten on the 08 h3's concerning this issue and it stated that the problem was an intermediate shaft. What is this and where is it located? I want to have good information next time I take the truck into the shop for this. My truck has the in line 5 cylinder. and I notice this vibration when the transmission is going through the gears at about 2500 to 3000rpm
Dec 5, 2008 at 5:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello Thanks for the donation. The intermediate shaft is part of your steering column. It could certainly cause the vibrations that you mention. I could not find this in the TSB list for the 09's and there are also no recalls to date for the 09's . Here is the TSB listing that you mention for the '08 models. Maybe this information can help the dealer diagnose your problem.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_7.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_2.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_1.jpg
Please post your results of the diagnosis so we can better help others with this same problem. Thanks for using 2carpros.com!
Dec 5, 2008 at 6:51 PM
