2007 Hummer H3 blowermotor stoped working in sep 2009
DAVID C CANTATORE
Heater problem
2007 Hummer H3 All Wheel Drive Automatic
no low/med/high but i have heat
Feb 17, 2010 at 12:26 AM
FACTORYJACK
  • 4,159 POSTS
Pull the red 5 pin connector off of the blower resistor, check for a burned terminal at one end. This is caused by poor connection. You can either obtain a terminal and new connector body, or get a harness for the HVAC. I would also replace the resistor.
Feb 17, 2010 at 3:43 PM
DAVID C CANTATORE
the resistor was bad pig tall not avable had ta order
resistor $40.00 list i paid $32.36 advanced /auto will be
at noon 2/18/1957
Thank you again
Feb 17, 2010 at 4:03 PM
