2006 Hummer H3 removal of brake pads
CHRISTOP
if the caliper does not come off how do i compress the 4 pistons after pads are removed?
Sep 17, 2009 at 6:23 AM
FACTORYJACK
  • 4,159 POSTS
You can use an old pad, and a prybar. or grab the edge with pliers. After you compress, one side(ex. inboard), wedge it or install a new pad, and then do the other side(outboard).
Mar 16, 2021 at 3:52 AM
