I unhooked my battery cable and when I hooked it back up my power door locks and drivers side power window stopped working?
Jan 13, 2009 at 3:42 AM
DEWEEDON
MEMBER
It sounds like you knocked out the driver door switch when you reconnect the battery from a voltage spike. There is a logic module inside the switch. Here is the location to help you fix the problem. Check out the diagrams (Below). Please let us know what happens.
Images (Click to enlarge)
Mar 26, 2010 at 3:03 AM
JIMM1416
MEMBER
Thank you for this post, I got a new switch for $98.00 and installed it all fixed! I love this site.
Jan 7, 2019 at 4:42 AM
2CP-ARCHIVES
MEMBER
driver door wondow stop working power locks stoped working and the remote will not work
Jan 7, 2019 at 4:43 AM
(Merged)
✓Experienced Mechanic
the common denominator is the wiring harness going from the door to the body. you may have to uncover the outside protector to inspect the wiring for broken wires
(Merged)
SGEHLERT
MEMBER
1 POST
I have a 2007 Hummer H3. Recently the drivers window and the power locks quit working. A few days later they started working again, and then now have quit working again. I've seen several people online have had this issue, but I can't find an answer anywhere?
(Merged)
HMAC300
you'll have to check and see if your wiring harness is badbetweent eh door and body. check to see if they areagetiing power or not. there are relays for the windows in the door and check the grounds, battery engine and body. all can do that.
(Merged)
AXELLIAM
MEMBER
1 POST
I have an 07 hummer H-2.Went to start it yesterday battery was very low but started.Drivers side window and door locks wont work checked both doors and key fob.Replaced Battery and checked fuse for door lock still wont work.I need help!
(Merged)
FACTORYJACK
Try first disconnecting the battery cables and shorting them together, this depletes the capacitors, sort of like a reboot. Hold them together for a minute or so, and check operation. Sounds like a logic lock condition, that may have been brought on by the low voltage.
(Merged)
TODD STANFIELD
MEMBER
1 POST
my power locks are not working..i hear the horn when my keyless entry sends the signal, but nothing happens. i have noticed this to be a problem with h3. any idea what the cause?
Jan 7, 2019 at 4:44 AM
(Merged)
DEWEEDON
MEMBER
caused by weak battery replaced battery then hold pos and neg cables together for a few seconds to discharge any charge in the system. Then connect the battery back and go.
(Merged)
MYNORSKY
MEMBER
1 POST
How much for repairing the automatic door and window llocks on a hummer h3. dealer is charging me 400.00 for this service how can i repair it without going to the dealer
(Merged)
FACTORYJACK
What are they repairing, i.e. what is the symptom? If it is a body control module for instance, it is going to need programming that only a GM techline terminal can provide.
