hummer h2 2009 break light not working.
18 MILES • 6.2L • V8 • 4WD • AUTOMATIC
RAJK9BUSA
my hummer h2 model 2009 break light's dont work while breaking, at the same time all parking light's are working porperly. I have already checked all blubs, fuse, and wiring.
Apr 28, 2014 at 6:46 PM
  • 31,937 POSTS
Check the brake light switch at the top of the brake pedal under the dash.
Apr 28, 2014 at 7:27 PM
RAJK9BUSA
I already check the brake light switch but switch is ok.
Apr 29, 2014 at 2:51 AM
RAJK9BUSA
Is there any other method to check the brake light switch?
Apr 29, 2014 at 3:04 AM
  • 31,937 POSTS
Check for power on both sides of the switch with the pedal pushed down.
Apr 29, 2014 at 9:18 PM
RAJK9BUSA
checked the brake light switch but switch is ok. what next?
Apr 30, 2014 at 2:51 AM
  • 31,937 POSTS
Check earth at both lights and check power at pin in globe holder, if no pore start probing down loom, if you have power at the brake light switch with pedal down (on light side ) problem is between switch and globe.
Apr 30, 2014 at 7:19 AM
