2006 Hummer H2 engine light
LIOTFAN
Engine Mechanical problem
2006 Hummer H2 V8 All Wheel Drive Automatic 95.000 miles
engine light came on checked with analyzer found p0300 code multiple cyl misfire changed coil packs,plugs,wires, ran awhile light back on same code, motor seems to run fine also changed gas cap to no avail sometimes light goes out then under heavy acceleration light comes on
Jun 1, 2010 at 10:39 AM
  • 75,988 POSTS
P0300 Random misfires normally caused by vacuum leaks and bad fuel
Jun 1, 2010 at 11:37 AM
