2006 Hummer H2 Airbag
2006 HUMMER H2
16,500 MILES • V8 • 4WD • AUTOMATIC
HUMMERHELP
I need to replace the passenger airbag in my hummer as well as the glovebox and i was woundering if that was something i could do my self and about at what cost? I also was woundering about the glovebox replacing it myself and where would i find these items?
Nov 5, 2008 at 2:12 PM
BRIAN 1
  • 1,030 POSTS
the glove box you could replace yourself,the airbag I would not attempt to fix yourself. airbags can be very dangerous if you are not trained to handle fixing this system. I spend alot of time in this area. leave it to the pro's. you can find these part's at the dealer.
Nov 6, 2008 at 5:08 AM
DR LOOT
  • 2,311 POSTS
With all due respect to brian 1, it's not just the airbag you have to change, you also have to change the sensor on the front bumper, you can probably handle the job, but remember as you are doing it, you will have to think and work like a suicide bomber.
Feb 28, 2009 at 3:02 AM
