Your rough idle, may be from detonation, are you running regular or premium? If you are running the regular it will pre-detonate, permium fuel with a higher octane helps reduce the detonation. And if you do not drive it very much regular fuel with its varnished will cause a sticky Valve.
SPONSORED LINKS
Friday, October 30th, 2009 AT 7:32 PM
