2005 Hummer H2 sunroof.rear view mirror and air conditionni
HDROCK67
Electrical problem
2005 Hummer H2 V8 Four Wheel Drive Automatic
my problem is when i was closing my sunroof it stop half open,the rear view mirror power went out and my air conditionnig is blowing hot air.Everithing was working fine before that happen.
Sep 22, 2009 at 9:21 AM
HMAC300
  • 48,601 POSTS
if you still have your book that came with the truck look for fuses and where they are located. some are under hood and others are under th eseat I beleive. the book wil explain where they are. It could also be a switch/ relay or motor. but i don't think so i think you blew a fuse . Itmay be one of the larger fuses that operates all 3 items.
Jan 16, 2010 at 10:42 AM
