2004 Hummer H2 windshield wiper trouble
80,000 MILES • V8 • 4WD • AUTOMATIC
CHOPPERGUY66
windshield wipers wouldn't shut off...fluid motor was running with no fluid coming out but its full..any clues on how to fix?
Nov 24, 2009 at 11:35 AM
HMAC300
  • 48,601 POSTS
there is a ground wire in th wiper motor and they wil break sometimes and need eitehr rplacing the wiper motor or fixing the broken ground. It is just below the cover of the wiper. The fluid motor may have ablocked line, depending where you are located in a cold climate the line may have froazen from not having enough washer solvent in it , instead being mixed with water. If the hoses aren't plugged then sometimes the pump vanes on the motor spin whenthe pump is activated. you'll have to replace the motor but check the hoses and also take a very small wire like used on parts tags and run down steel part by wiper blades as this plugs as well......
Jan 16, 2010 at 10:36 AM
