2004 Hummer H2 windshield wiper motor
130,000 MILES • V8 • AWD • AUTOMATIC
FCSMILEK
Upon arriving in MT with sub freezing temps, my windshield wipers will not make a complete revolution. They only go about 1/4 of the way and stop. If I flip the wipers away from the window, like you do before a snow storm so that the wipers don't get stuck to the windshield, they rotate fine. They when the wipers are put back into there normal position, touching the windshield, they only move 1/4 of the way and stop. Is my wiper motor worn out? Or is there a control module?
Thanks
Dec 18, 2008 at 11:06 AM
RICH6568
I had the same problem and found that the nut that holds the motor to the wiper assembly was finger loose ,but I also discovered that the gear was broke inside. The motor works fine just the gear was bad. I went onto amazon.com and got a rebuilt motor for around $160.
Feb 13, 2009 at 10:50 AM
