2004 Hummer H2 windshield washer
2004 HUMMER H2
65,000 MILES • V8 • 4WD • AUTOMATIC
DOAKGILLIAM
have a 2004 Hummer H2...the winshield washer comes on and stays on when I start the truck....what do I do? Nothing works to shut it off....
Oct 30, 2010 at 1:37 AM
FACTORYJACK
  • 4,159 POSTS
Under the front upper cowl panel, where the wiper motor is, there is a module attached to the motor. Replace that module. To remove the cowl panel, remove the wiper arms, remove the right and left caps, two screws, and the cowl panel. The panel is easier said then done, as the clips can deform and increase retention. If you can lift up on the sides, and see the clips, get something in there to pry and release them, is about the only tip I can offer. It can break the cowl panel, if excessive pulling force is used.
Oct 30, 2010 at 9:14 AM
