2004 Hummer H2 trans electrical problem
115,000 MILES • V8 • 4WD • AUTOMATIC
FIRE09
key will not come out of ign. trans fuse pops , ran new wire with 10 amp fuse from ign switch to power lead at trans is there any common items with this vehicle that should be checked
Oct 12, 2009 at 11:31 AM
DR LOOT
  • 2,311 POSTS
Try checking your safety neutral switch on the transmission that may be causing the problem.
Oct 30, 2009 at 12:35 PM
