2004 Hummer H2 service brakes required
2004 HUMMER H2
79,831 MILES • V8 • 4WD • AUTOMATIC
MR BRAKES
brake service required is on , abs light, traction control light and brake light are on.
we just replaced the brake pads and all 4 rotors, and a left front hub bearing.
Oct 2, 2009 at 10:23 AM
FACTORYJACK
  • 4,159 POSTS
Ideally it would need scanned for ABS trouble codes, and that would direct you toward the fault. The only probable fault you could have created with the brake service is the hub that was replaced. It houses the wheel speed sensor as well, check the connections for that sensor.
Oct 5, 2009 at 5:20 PM
