2004 Hummer H2
KYNDRAHOLLENBECK
  • 2004 HUMMER H2
  • 6 CYL
  • AWD
  • 50,000 MILES
The Hummer drives fine on the highway or for wide turns. I had the drive lives and drive train replaced as well as front axel. Now when I go to turn into a parking spot or make a sharper turn it feels like the vehicle is really tight. Just like a vehicle feels when its in locked into 4WD in town instead or 2WD. It wasnt doing this before.
Thursday, February 19th, 2009 AT 8:44 AM
FACTORYJACK
  • 4,159 POSTS
It could be locked in four wheel drive. Try switching it from 4hi open to 4hi locked and see if it changes. They used a plastic mode shift fork in the transfer case that can break, and/or the mode collar can break also. It is a simple repair, that requires the transfer case to be removed and partially disassembled.
Thursday, February 19th, 2009 AT 9:57 PM
