2003 Hummer H2 Tune Up
2003 HUMMER H2
87,000 MILES • V8 • 4WD • AUTOMATIC
HUMMER 1
I just figured that there are a few things that I should do as far as a tune up. I do all the normal things like grease and oil. Should I do Plugs, Wires, ..... any suggestions?
Nov 16, 2008 at 3:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
With 87k miles on it and not knowing when everything was changed last, I am going to list some things I changed on my vehicle around that odometer reading.
Plugs
Plug wires
Oil
Fuel filter
Air filter
Checked tire tread
Checked suspension (grease, wear/tear, etc..)
Timing belt/chain
Checked battery and alternator
Checked coolant for correct color/level
Had all around alignment and tires rotated.
Hope this helped.
Nov 16, 2008 at 3:51 PM
