2003 Hummer H2 thermostat
2003 HUMMER H2
88,000 MILES • V8 • 4WD • AUTOMATIC
MSHOPEY
do i need to drain the antifreeze first? never seen the thermostat on the bottom radiator hose.
Oct 31, 2009 at 4:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, you will need to drain the cooling system before replacing the thermostat.
Oct 31, 2009 at 3:29 PM
FACTORYJACK
  • 4,159 POSTS
Where the lower hose meets the water pump is where the T-stat is.
Nov 4, 2009 at 1:29 PM
