do i need to drain the antifreeze first? never seen the thermostat on the bottom radiator hose.
Oct 31, 2009 at 4:57 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Yes, you will need to drain the cooling system before replacing the thermostat.
Oct 31, 2009 at 3:29 PM
FACTORYJACK
Where the lower hose meets the water pump is where the T-stat is.
Nov 4, 2009 at 1:29 PM
