2003 Hummer H2 noise
89,000 MILES • V8 • 4WD • AUTOMATIC
RICH6568
I know I will need tires ,but i get a serious vibration like it might be a wheel bearing. any suggestions
Feb 13, 2009 at 10:44 AM
2CARPRO JACK
  • 11,533 POSTS
89k is about right for front hub bearings. Try lifting and supporting it and see if there is any play top to bottom as well as front to back in the wheels. Also check the pitman and idler arms, they tend to wear out about that mileage as well
Feb 13, 2009 at 1:09 PM
DR LOOT
  • 2,311 POSTS
And if you have put oversize tires on it, you will make the problem worse, I learned that the hard way, so I sold my Hummer and upgraded to the next level M939-A1
https://images.2carpros.com/forum/automotive_pictures/307270_Champ_Grader_and_Kids_031_2.jpg
Feb 19, 2009 at 12:58 PM
