2003 Hummer H2 engine stall
132,000 MILES • V8 • 4WD • AUTOMATIC
FOREST GREEN
It won't shift to higher gear automatically. I have to take my foot off the gas and then press it again to shift gear. It wont shift gear, even I press gas to red line.
Jul 4, 2009 at 12:42 PM
DR LOOT
  • 2,311 POSTS
First off, this is not a woman, by pressing the accelerator to the floor she is not going to respond, do you have an engine light on? have you checked the transmission fluid? the transmission is electronic, if you do not have a scanner. You will not be able to repair it.
Oct 30, 2009 at 12:51 PM
