My rear hatch and rear doors will not unlock. I manually unlock the rear doors but hatch cannot be opened.
Nov 2, 2009 at 1:34 AM
FACTORYJACK
✓Experienced Mechanic
If the doors lock with power, but don't unlock, swap the relays in the I/P fuse block and see if the behavior changes. If they neither lock or uinlock, check the 20A locks fuse in the I/P fuse block. It is on the left side of the instrument panel, under the endcap. The legend for the fuse block should be on the underside of the cover.
Nov 4, 2009 at 1:35 PM
