truck died 6 months ago...had the hummers' system checked and it wasnt the alternator or starter..it was the battery,so i replaced it.now truck having weak starts (to point where clock resets each time).manuel says warning should appear on DIC that battery not charing ....but isnt? what is causing the dead battery?could this be a bad terminal ?... relay?...fuse issue? also front heated seats will not turn on,is this a conjoined problem with battery not charging.rear heated seats work fine. i found nothing of fuses for frnt heated seats in the owners manuel any where ,but did for the rear heated seats.
Oct 21, 2008 at 2:51 PM
