2004 Hummer H1 Hazard Light won't Flash on One side
2004 HUMMER H1
TEBON
Electrical problem
2004 Hummer H1 Four Wheel Drive Automatic 29000 miles
I am having issues with my Right (passenger) Hazard light. I have attempted basic fixes, but am still experiencing the issue.
What I have tried:
- The bulb works during turn signal mode, but not in hazard.
- I checked the bulb to see if it is connected.
- I checked to make certain the terminal is recieving voltage.
- I switched the bulb from the opposite, working side.
- I checked for continuity in the turn signal switch on the steering column.
I am still experiencing the issue, and the manual does not seem to have much help, stating that there is not much that can go wrong. Any help would be appreciated!!
Jan 13, 2010 at 8:17 AM
DR LOOT
  • 2,311 POSTS
I can help you but I need more information, you have told me everything you have done but you did not tell me what the results one by one.
Oct 24, 2010 at 11:16 AM
