Hub repair fixed brakes
300,000 MILES • V8 • RWD • AUTOMATIC
PETER DHOOGHE
My brother's car's brakes went out the other day and he noticed that there was a liquid on the outside of the wheel cap and so thinking it was brake fluid. I opened it up to see what was wrong. Turned out to be bearing grease as the bearing had faltered. So I cleaned out all the grease and changed both sets of bearings. This somehow fixed his brakes. it also leads me to believe that there must be something more wrong with the brakes seeing as one bearing going out caused all the brakes to go out. I am lost for ideas.
Thanks
Jun 12, 2017 at 8:12 AM
HMAC300
  • 48,601 POSTS
it may have gotten grease on the pads and they did not work to well that way. or from the bearing going out the rotor/drum would not make good contact.
Jun 12, 2017 at 8:38 AM
STEVE W.
  • 15,418 POSTS
More than likely the bad bearing allowed the rotor to move around so the caliper could not really squeeze the braking area. Once the bearing was replaced the rotor now traveled in the right spot so the pads could grip it.
Jun 12, 2017 at 9:21 AM
PETER DHOOGHE
Would this effect all four brakes? Should I look for a more serious brake issue?
Jun 12, 2017 at 11:11 AM
HMAC300
  • 48,601 POSTS
if the brakes are okay then drive it. if not then look at others front and rear. it may be the pads are worn too bad in front from bearing bad and need replacing both sides.
Jun 12, 2017 at 11:15 AM
