Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Elantra
Tires
Hub Cap
Loose hubcaps
2010 HYUNDAI ELANTRA
28,000 MILES • 4 CYL • AUTOMATIC
INMYHEART28
MEMBER
If a couple of clips are loose on a couple of hubcaps but they are still on well is this a problem?
Aug 19, 2021 at 10:10 AM
Experienced Mechanic
As long as they are still tight, you should be okay. How loose are the clips?
Aug 19, 2021 at 12:46 PM
INMYHEART28
MEMBER
A couple clips may be broken or loose I’m not sure. But the hubcaps are still fully on held pretty close by the other clips.
Aug 19, 2021 at 1:07 PM
As long as when you pull on them, they feel tight and like they won't come off, you should be fine.
If you can, take a pic of what you are dealing with and upload them for me to see. Hopefully, I can give you some ideas on how to repair them.
Aug 19, 2021 at 1:27 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
