Hub assembly
2005 HYUNDAI TIBURON
114,000 MILES • 2.7L • 6 CYL • FWD • AUTOMATIC
SHANNON RICHMOND
Hi, my wheel bearing needs to be replaced. I have tried two different brands and they both fit with a little wobble. I tried the one's from Autozone, Duralast 512198 and Moog 512428. Neither one fits snug and they're both supposed to be compatible with my car. Please help. Any suggestions?
Thanks,
Shannon
Oct 26, 2016 at 6:43 AM
KOOLCADDY6
  • 60 POSTS
Are you installing a hub and bearing assembly or is it a bearing with a pressed in bearing race ?
Oct 26, 2016 at 7:40 AM
WRENCHTECH
  • 20,761 POSTS
Have you tightened the axle nut before checking it? That is what tightens everything up.
Oct 26, 2016 at 8:53 AM
SHANNON RICHMOND
It is a hub/bearing assembly.
Oct 26, 2016 at 10:33 AM
WRENCHTECH
  • 20,761 POSTS
Yes, and are you torquing down the axle nut?
Oct 26, 2016 at 10:35 AM
SHANNON RICHMOND
I did tighten the nut before checking it. Someone mentioned that it could fit different depending on if you have ABS brakes or not.
WRENCHTECH
  • 20,761 POSTS
It is probably not tight enough. the axle nut pulls the bearing races together.
Oct 26, 2016 at 10:38 AM
SHANNON RICHMOND
Yes.
Oct 26, 2016 at 10:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Shannon,
If you didn't take the steering knuckle completely off and have the bearing and hub pressed in by a garage or some with a specialized tool for pressing them in you most likely do not have it tight enough, it takes quite a bit of torque to get the hub and bearing completely in place without special tools and equipment. Also, were you able to get the Snap Ring back into place?
Mark
Oct 28, 2016 at 10:58 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hey Shannon,
Just checking in to see if you got the problem fixed.
Thanks
Mark
Nov 3, 2016 at 9:15 AM
