Whats the difference betwenn hp at the crank and at the wheels
Feb 27, 2016 at 4:22 PM
HMAC300
✓Experienced Mechanic
hp at crank is what engine makes, hp at wheels is the loss due to trans and axle. tv shows can really screw this up by showing dyno results at wheels. if you increase engine it will increase at wheels normally
Feb 27, 2016 at 11:53 PM
REDBEARD726
MEMBER
So if my car says 240hp 280 torque thats at the crank?
Feb 28, 2016 at 6:07 AM
HMAC300
yes btw a lot of dynos out there are not really correct because they don't have temperature correction or run at temp they are supposed to . It can make a difference, especially if it's in a room with no air quality. All OEM manufacturers are
