Howling sound
130,000 MILES • 4 CYL • FWD • AUTOMATIC
JEFFLOPEZ
At speeds over 35 mph there is a very loud sound coming from the rear it sounds like it needs to shift but the tachometer shows that it is shifting.
Oct 27, 2016 at 12:46 AM
HMAC300
  • 48,601 POSTS
check for a bad wheel bearing and or a brake problem , might be squealers on brakes letting you know it is time for brake job. with that sound goes away when brakes are applied.
Oct 27, 2016 at 2:30 AM
JEFFLOPEZ
It sounds like it needs to shift gears.
Oct 27, 2016 at 3:30 AM
JEFFLOPEZ
But it is shifting according to the tachometer. But it just whines out like its very high rpm's.
Oct 27, 2016 at 7:09 AM
HMAC300
  • 48,601 POSTS
well if sound is coming from back and you have forward then it has to be what I replied or something similar. you can have it scanned for codes at auto parts see if they come up with anything. like a bad converter etc.
Oct 27, 2016 at 8:39 AM
