Howling sound
JEFFLOPEZ
  • 2007 HONDA ACCORD
  • 4 CYL
  • FWD
  • 130,000 MILES
At speeds over 35 mph there is a very loud sound coming from the rear it sounds like it needs to shift but the tachometer shows that it is shifting.
Thursday, October 27th, 2016 AT 7:46 AM
HMAC300
  • 48,601 POSTS
Check for a bad wheel bearing and or a brake problem, might be squealers on brakes letting you know it is time for brake job. With that sound goes away when brakes are applied.
Thursday, October 27th, 2016 AT 9:30 AM
JEFFLOPEZ
It sounds like it needs to shift gears.
Thursday, October 27th, 2016 AT 10:30 AM
JEFFLOPEZ
But it is shifting according to the tachometer. But it just whines out like its very high rpm's.
Thursday, October 27th, 2016 AT 2:09 PM
HMAC300
  • 48,601 POSTS
Well if sound is coming from back and you have forward then it has to be what I replied or something similar. You can have it scanned for codes at auto parts see if they come up with anything. Like a bad converter etc.
Thursday, October 27th, 2016 AT 3:39 PM
