Howling noise when reversing from front wheels.
100,000 MILES
DMB08
There is brake pad noise and wear and the pads likely need to be replaced but does this cause a howling noise or is more likely a bearing/hub issue? Do I need to get the hubs pressed from the steering knuckle on this model?
Aug 1, 2013 at 10:27 PM
HMAC300
  • 48,601 POSTS
howling noises are usually wheel bearings or axles making noise the bearing is bolted to spindle and axle, axle nut first then drive backwards then remove nuts/bolts holding bearing in.
Aug 2, 2013 at 12:06 AM
DMB08
Seems like it was just the brakes as its stopped but I will keep this in mind. Thank you for the quick reply!
Aug 7, 2013 at 5:01 AM
