Good evening,
Yes, it is simple.
You need a new fan. You will need to remove the flex fan and remove the spacer behind it to the water pump pulley.
Then you need to get studs for the mounting of the fan. They need to be about three inches long.
Then get your new clutch fan with a new eight blade fan and install it on the truck.
It activates by heat and speed.
SPONSORED LINKS
Monday, March 25th, 2019 AT 4:05 PM
