How to torque a cylinder head and big end bearings
174,000 MILES
LEON KATJIMUNE
Easy steps how to torque a cylinder head and to torque the big ends bearings. I had removed the cylinder head of my golf and plus the big ends bearings, to replace piston rings and also new big ends bearings. So I need a solution how torque the cylinder head and also how to torque the big ends bearings.
Oct 4, 2013 at 5:21 AM
EXOVCDS
  • 1,882 POSTS
Cylinder head gasket should come with Torque Specifications and order of tightening.
Usually 33ft lbs, 44ft lbs + 2 x 1/4 turns (stretch bolts, always replace).
Recommend a Haynes manual... Bentley Manuals are better.
Thomas
Oct 4, 2013 at 8:04 AM
HMAC300
  • 48,601 POSTS
make sure to follow what he says
Oct 5, 2013 at 1:29 AM
