Thanks very much Roy. I'll it out I'll let you know when it fix thanks once again bro.
Mar 20, 2020 at 10:42 PM
✓Experienced Mechanic
You are welcome.
Always glad to help.
Mar 20, 2020 at 10:52 PM
CASPER KAUKUI
MEMBER
Hello Roy, I've done the timing perfect, did the test run perfect, but there's a sound coming from the back a knocking sound sometimes when I reverse and when I take-off. Also when at high speed or going downhill there's a rattling sound on the right front side of the engine.Any idea what the cause is?
Mar 23, 2020 at 11:18 PM
Okay, good. Can you upload a video of the noise for me to hear?
Mar 23, 2020 at 11:24 PM
CASPER KAUKUI
MEMBER
Thanks. Okay, I'll do that first thing in the morning...
Mar 23, 2020 at 11:31 PM
Sounds like a plan.
This could be something like a water pump or a bearing that is run by the drive belt on the engine.
