How to Service Stability control system?
122,959 MILES • 4.6L • V8 • 2WD • AUTOMATIC
KNAMELESSONE
My info center is telling me to service stability system and my ABS and traction control lights are on. I need to know what to do to fix this because I reset all the codes and started the car and the lights turned back on before I even moved the car. My airbag light is on too but it’s been coming on and turns itself off for a few months now.
Mar 21, 2023 at 8:51 AM
  • 55,845 POSTS
The airbag light seems like it will be a separate problem so please start a new question about that. The service stability system and my ABS and traction control lights are probably due to a wheel speed sensor that is not reading correctly which could be due to a front bearing hub that is going out and the sensor has lost connectivity to the reluctor wheel. This video will show you how to see which sensor is bad:
https://youtu.be/rTtAnsOlZU4
I have left how to change out the ABS wheel sensor and bearing hub in case you need it. Check out the images (below). Please let us know what happens.
Mar 22, 2023 at 8:57 AM
