How to reset maintenance light.
118,000 MILES
DARYLPGRAVES
I have tryed to reset it with the odometer but it will not work. I have on the turn signal a reset also but it will not work , If some one can help that would be great. This is all new to me just got the car last week used with no service manule.
May 7, 2013 at 11:51 AM
Resetting the service reminder indicator (SRI)
Hint: The indicator can also be reset using VIDA vehicle communication.
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on.
Note! If the lamp flashes, it may be because one of the service parameters has not been programmed.
Proceed as follows to reset the service reminder indicator (SRI):
Ignition position I
Press and hold in the reset button for the trip odometer
Ignition position II
The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
Resetting the service reminder indicator (SRI), model years 2002-
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 s each time the ignition is switched on.
Ignition position I
Ignition position II.
Note! Turn the key to position II within 2 seconds.
Hold the reset button for the trip meter pressed in until the original value has been reset.
Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
May 8, 2013 at 12:39 PM
