How to replace valve assembly, vent (ORVR)ORVR
60 MILES • 1.7L • 4 CYL • 2WD • MANUAL
MANDO ACUNA
  • 5 POSTS
I just drained and cleaned the tank. What came out with the gas was fuel with the looks and viscosity of oil. There were chunks of solidified fuel that looked like peanut brittle. It plugged the fuel pump. The engine only has about 60 miles. The gas tank obviously has many more.
Oct 27, 2019 at 6:51 PM
STEVE W.
  • 15,418 POSTS
Welcome to 2CarPros. Your description says the car was parked with a tank at least half full and left alone. The peanut brittle is what is left of the gas that was in it after the fuel evaporated. If this is a steel tank I wouldn't even try to use it as the interior is probablt starting to rust and corrode. If plastic I would be very careful to clean it very thoroughly. Next I would replace every fuel line the fuel rail and injectors as well. The dehydrated fuel would be in everything related to the fuel system and would constantly be plugging the system as it broke free inside the fuel parts. Inside the injectors the varnish would plug the jet tips and the solenoid assembly. If you do use the original tank I would also add an inline fuel filter that is easily changed.
Oct 27, 2019 at 7:33 PM
MANDO ACUNA
  • 5 POSTS
Thank you. The tank is plastic. It is all clean now. I used a combination of baking soda, vinegar and water, and scrubbed it with kitchen dish brushes. And I do intend to change everything you mentioned above, and adding the inline fuel filter.
So, how do I remove the valve assembly (ORVR) from the fuel tank?
Oct 27, 2019 at 8:36 PM
STEVE W.
  • 15,418 POSTS
If that image is your tank you can take if off at the connections then remove the charcoal canister and replace it. I looked for a better diagram but the Honda City wasn't sold in the US, just everywhere else! On many Honda's they use a valve that twists into place like the one in the image. However they also have ones that are glued into the tank. Those are not easily removed, However you could use Acetone to flush the valve out, but it would need to soak to soften the varnish. Think you could take a picture of the pieces and tank and post it here? That would let me see the exact items. I would just use the Fit diagrams as they are based on the same chassis, I just don't trust that Honda actually used the same exact parts.
Oct 28, 2019 at 6:35 AM
MANDO ACUNA
  • 5 POSTS
Thank you for your help! My bad, my car is a 2003 Honda CIVIC, not CITY, EX.
Nov 21, 2019 at 11:04 PM
MANDO ACUNA
  • 5 POSTS
I have bought a new fuel tank strap, but I do not know which way it goes. Neither the vendor nor the manufacturer have responded to my query. Thank you for your help.
Nov 21, 2019 at 11:06 PM
STEVE W.
  • 15,418 POSTS
Okay, being a Civic makes it much easier to deal with. The tank straps go in place as in the picture. In your picture the longer legs to the left go toward the front of the car. Usually they are a fight to install as they use the bolts to tension the straps and hold the tank so you end up doing the octopus dance trying to hold things in place. What I normally do is get a floor jack and set the strap in place over it, then jack it up to hold the tank into place. Now you can position the strap and tighten it in place. Put all 4 bolts in a few threads before you tighten any down.
Nov 22, 2019 at 12:54 AM
MANDO ACUNA
  • 5 POSTS
Thank you! Have a blessed day.
Nov 22, 2019 at 2:01 AM
STEVE W.
  • 15,418 POSTS
You are welcome.
Nov 22, 2019 at 3:00 AM
