How to replace throttle position sensor?
135,689 MILES
JUSTWILDER
Need to replace the throttle position sensor on my truck.
Nov 25, 2019 at 2:41 AM
DANNY L
  • 5,648 POSTS
Hello again.
I've attached picture steps below on how to replace the throttle position sensor on your truck. Steps for module programming are included as well. Hope this helps and thanks for using 2CarPros.
Danny-
Dec 31, 2020 at 12:58 PM
SCOTTMCKEE
My mechanic tells me the throttle body along with the sensor inside is bad, as my redeced engine power
alert comes on often now . Im told by mechanic that sensor is sealed inside throttle body and I need to
replace the entire throttle body $320 at GM dealership and $307 at Advance Auto. Just need someone
to confirm this info before I go spend this amount of money . Thanks Scott Bolivia NC
Jan 7, 2021 at 4:13 AM (Merged)
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
what hes telling you is true.
SCOTTMCKEE
I also have read that faulty wiring at the throttle body and or dirty
throttle body can cause the red end powr dislpay to come on. Just trying cover all posible causes before buying the new throttle body . Thanks
Scott
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
of course its always a good idea to check wiring. unplug the TPS and look at the plug for dark or brown marks as this would indicate a poor connection
CANADAM12
Engine Performance problem
2001 GMC Sierra V8 Four Wheel Drive Automatic
My trucks throttle has been sticking in the cold while on the freeway. (not very safe) Must shut truck off and restart to bring rpm's back down. Engine runs at erratic idle when stopped in park or in gear. Ran a diagnostic and got codes p0101, p0106, p0121. Suspect throttle position sensor. Any advice. Where is sensor located? It's -35 c outside and I don't want to be crawling around in the snow trying to find it.
  • 75,988 POSTS
See below-The TPS on V8's are at the same similar location
https://images.2carpros.com/forum/automotive_pictures/12900_tps_16.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_tps1_9.jpg
Jan 7, 2021 at 4:14 AM (Merged)
