how to replace the regulator in the driver side door?
19,521 MILES • 6.4L • 6 CYL • 4WD • AUTOMATIC
RAYMOND LEAHY
bent regulator.
May 18, 2021 at 4:14 PM
Clearly you are going to need to remove the door panel so here is a guide that will help with this and the repair:
https://www.2carpros.com/articles/door-panel-removal
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Below is the entire process from the manual on how to replace this. Please let us know if you need other info. Thanks
May 20, 2021 at 3:18 AM
