How to replace the fuse box?
150,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
CHARLESTUCK
  • 66 POSTS
There are fuse slots that have no current. I disconnected the battery and cleaned each terminal thoroughly. Only a couple of them have current now, so I have ordered a replacement fuse box. I need to be able to swap wires from the old fuse box to the replacement. Thanks.
Jul 20, 2022 at 12:36 PM
  • 55,554 POSTS
It might be the ignition switch that is causing the issue, I would check the power outputs at the switch. Here is a guide to help you with the power distribution wiring diagrams that feed the fuse panel and I found some fuse panel diagrams to help understand what you are doing:
Jul 21, 2022 at 6:17 AM
