How to replace purge valve
139,100 MILES • 5.7L • V8 • 2WD • AUTOMATIC
SEBASTIANTUDON
  • 30 POSTS
How do I go about to removing and replacing the purge valve?took one line off but the other one kinda stuck on there.do I need to remove the purge from the bracket to replace?
Apr 27, 2020 at 2:36 AM
If the line is fighting a little bit, I would remove the purge except for that line and then you will have more room to get it off.
I attached the process on how to remove and replace it. Let us know what happens and we can go from there. Thanks
Apr 27, 2020 at 3:59 AM
  • 110,251 POSTS
If you press the release, gently wiggle the connector while turning 1/4 turns back and forth. It should come off.
_______________________________
Here are the directions for replacement. The attached pics correlate with the directions.
2004 Pontiac GTO V8-5.7L VIN G
Procedures
Vehicle Powertrain Management Emission Control Systems Evaporative Emissions System Canister Purge Control Valve Service and Repair Procedures
PROCEDURES
pic 1
Evaporative Emission (EVAP) Canister Purge Valve Replacement
Removal Procedure
1. Disconnect the EVAP engine vacuum pipe from the EVAP canister purge pipe.
pic 2
2. Disconnect the engine compartment EVAP pipe at the EVAP canister purge valve.
3. Disconnect the EVAP canister purge valve harness.
4. Remove the EVAP canister purge valve.
pic 3
Installation Procedure
1. Install the EVAP canister purge valve to the bracket.
2. Connect the electrical connector to the EVAP canister purge valve.
pic 4
3. Connect the engine compartment EVAP pipe at the EVAP canister purge valve.
4. Connect the engine vacuum pipe to the EVAP canister purge valve.
_________________________________
Let me know if it doesn't come off. Note there is a rubber o-ring in there that may have a bit of corrosion on it causing the problem.
Apr 27, 2020 at 4:00 AM
