How to replace idle air control valve?
96,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
TONYLSF
car isn't turning on, when car was on the idle when high passed 1 . battery is brand new. after checking code, I got error code P0505 idle control system P0174 system too lean bank 2 cleaned with carburetor with throttle cleaner and cleaned master flow with master flow cleaner. problem temporarily fixed, but issued retuned next day.
Nov 9, 2024 at 11:57 PM
  • 55,711 POSTS
There is no idle air control valve on this truck. There is a problem with the truck holding the idle speed, this is why you get this code and with the lean code it sounds like you have a vacuum leak.
Code P0505: Idle Control System Malfunction
Code P0174: System Too Lean (Bank 2)
Here is a guide to help you find the leak, use it when the engine is cold only:
Here is the lean mixture guide to help understand that problem as well:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Please go over these guides and get back to us.
Nov 10, 2024 at 1:17 AM
