How to replace the hazard light switch?
80,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
ZMATTJ
  • 5 POSTS
Hello.
The hazard light switch is not activating the indicator lights when pressed.
It was this way when the car was purchased second hand.
The is also no noticeable damage to the existing switch or the area around it.
Aug 27, 2023 at 11:13 PM
  • 55,845 POSTS
You will need to remove a couple of panels first, here is how to change the hazard switch out. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 28, 2023 at 4:53 AM
ZMATTJ
  • 5 POSTS
Cheers Ken.
Would you also be able to recommend somewhere to buy one from?
Cheers
Aug 31, 2023 at 11:53 PM
  • 55,845 POSTS
Sure, here is one for $20.00:
https://amzn.to/3qNZX0R
Let me know if you need anything else to fix the problem.
Sep 1, 2023 at 3:37 AM
