Can I replace this myself, or is it replaced only by the dealer? Is there a do-it-yourself video for this? Also, where do I but the fuse?
Mar 19, 2020 at 1:32 PM
✓Experienced Mechanic
Most parts stores will sell you the fuse. They are not expensive. Also, here is a link that explains things as far as a car fuse and hot to check and replace one. It really isn't hard.
Let me know if that helps or if you have other questions.
Mar 19, 2020 at 3:11 PM
Good morning,
According to the wiring diagram for your car, the fuse box at the lower right side kick panel contains the fuse for the lighter. I attached a picture for you and circled the fuse number.
