Fan motor replacement
1,500,000 MILES • 6 CYL • AUTOMATIC
PAUL SANCHEZ
How to replace fan motor step by step instructions needed.
Jun 1, 2018 at 12:43 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
For blower motor replacement:
1. Disconnect battery ground cable.
2. Remove right sound insulator panel from under instrument panel.
3. Remove rear retaining screws from electrical convenience center, then loosen front screw and slide convenience center out.
4. Disconnect electrical connector at motor and remove harness from clip.
5. Remove blower motor mounting screws and blower motor.
6. Reverse procedure to install.
Jun 1, 2018 at 1:02 AM
